I have a plate amplifier (2-channel) mounted in the back of a Yamaha NX-E700 and that works very well.
i have also a button expansion and IR receiver board to use an IR remote control. But this doesn’t seem to be compatible, the connector on the amp is much smaller than on the button-board.
In the manual of the plate amp a connector for button and IR receiver is marked, but how can I make this work? do I have the wrong button board?
There are contradictory statements here. On the pictures of the plate amp, you can apparently connect an infrared receiver. But this requires the button board, which in turn is not compatible with the plate amp. somehow something is still missing…
Hi Marcel,
Sorry my mistake, It doesn’t appear that the Arylic button board is compatible with that unit.
The manual does show how buttons can be added, but it’s a do it yourself option using momentary push buttons and resistors. I guess it would be dependent of your DIY skills to make this option happen.
Steve
