Hi. I’ve bought an used s50pro. I’ve tried to reset using rear button but doesn’t work. May you help me? I can’t reach wi fi Andress with my Android Phone, and the message is no ip Andress. Thanks
I have S10 and found it easier to cat5 it to router to start and I believe you have to hold power button down before plugging in to actually reset it. Here’s link to manual on newer S50s
Welcome to the Forum and hope you get some musical satisfaction soon
@CAT22 advice is spot on. Hook it up the the Router with a cable to start with and take it from there.
Regards, Kevin
