S50Pro Plus - Tidal skipping tracks after 15-20 seconds
Has anyone experienced any issue with the Arylic S50 Pro Plus when streaming from Tidal ?
The Tidal account is a HiFi subscription with the highest res music output selected.
Once the playlist is open, each song will play for approximately 15-20 seconds and then skip to the next song. Have tried multiple S50 Pro Plus (hard wired) and each does the same thing however if I use a standard 3G/4G LTE router to bypass the clients network, the full song plays until the end, so I am thinking it might be a setting on the clients network.
It only happens with the Arylic and not with any other brands of streamers on the same network, playing the same streams from Tidal.
Any ideas on what network setting could be causing this problem ?
Maybe you can try to change the streaming audio quality in the Tidal app to see if the issue is fixed.
If not, then you can try to play Tidam music offline on your device.
If so, you can use AudFree Tidal to MP3 Converter to save Tidal songs as local files, then move the files to your device for offline playback.
