The default step for increase or decrease of volume in S50 Pro+ is 5 through the remote. Is it possible to adjust this step to other values like 2/10 etc ?
Yes, but you have to tune it via TCP API command, for example to set steps to 2: MCU+PAS+RAKOIT:VST:2&, and it support values from 1 to 10.
You could send it with the tool.
Thanks a ton. Worked like a charm. Now I have changed two of the most annoying UI issues (to me) of S50 Pro+. The other one being audible beep during volume change.
Great, and you could send MCU+PAS+RAKOIT:BEP:0& to disable the beep sound
Already done that. Picked it up from another forum post.
