Hi there i have a S50 Pro+ which i have put some FLAC files on a USB stick and towards the end of the song the song jumps or skips a little every time on every song.
Anyone know of this problem and maybe a fix have firmware vers 4.6.415145.35
I’ve the same problem with MP3 or other format on USB stick.
Any Idea ?
it seems also that only 2049 files are visible even if there is more on the Key. I assume it’s linked to the format shall I use NTFS or FAT32 or exFat or ?
Thanks for pour feedback
There is a limit to the number of files that the device can handle plugged into the USB, The device has a 1000 song limit and also cant deal with very large USB drives even with small files loaded.
This is to do with the processing power of the chip onboard and so the software has a file limit set.
I couldn’t get a USB 125GB to work but the 16,8,4gb all worked ok.
The Device is also a very good at accessing DNLA, so if your files are on a Music Server or your Laptop/PC with media access rights opened, the Arylic can pull the music off the ethernet.
I’ve made additional test this night. I’m using a 256Go USB key (FAT32).
The S50 Pro+ device is able to read it except the limitation of the 2049 files as already mentioned (not far away for 2exp11 = 2048), that already a lot of files ;-).
I’ve also connected this key to the USB PORT of my internet BOX to use it as a NAS.
All files are visible using 4stream app.
The only issue I’ve is that I cannot play the files directly by cliking on.
I found a workaround by adding them to a playlist or associating an album to a favorite (1 to 9).
When it is playing I can use the “play next” if I want to jump to different artists/songs or a new favorite to jump to a new album.
Any advice to make it a bit more simple ?
I wrote about the same problem weeks ago, the problem is not only with a usb key but also streaming music from the NAS. It can’t be a problem related to the number of songs: it worked perfectly before the last upgrade, it was not gapless form a song and the following one, but the sound was ok till the very last second of each song. I do hope they will deliver a new version of the firmware fixing this problem.
Thanks for the info yes I am still having this problem as well hope they come out with another software update to fix this bug soon, or I might have to buy a bluesound node.
Hi all,
if someone from Arylic reads here can give us an indicative date of when the new firmware update will be released?
I bought the S50 PRO+ for over two months to use it as a network streamer but due to this annoying bug it is unusable.
I only use it to listen to web radios but I would like to do something more with it…
Hi all,
I added a NAS to my home system and connected it to the S50 via wi-fi.
Then I converted all my CDs to FLAC and copied them to the NAS disk.
Playing songs, with my great surprise I saw that the the jumping and skips was gone !! It only occurs in very rare situations when, for example, I handle a lot with the app.
The converted CDs are over 300 so it was not a problem of quantity.
Apparently it’s just a USB reading problem.
We always wait for the firmware update but using a NAS I can say that the device works fine…
Regarding the issue of song jumping in the end 5 seconds of each song. The reason is caused by gapless feature. Because the platform should have some limitations to handle two files on USB at the same time, so it will cause the system busy and affect the current audio. We’re also very struggled for this issue, as it would also cause complaint when remove the released gapless feature.
As it works fine with NAS, it would be compromised solution to move songs to NAS.
And what is meant by the word NAS? DLNA, shared network folders? It’s just that dlna is also played with a limitation - the selected song and about 100 songs next to it, the rest of the songs seem to not exist.
Hello! is there a way to disable the gapless feature? for me is quite better to have a gap but good quality. Anyway even with music in the nas…i had some problems, as written in a old message. Thank you.
Hello! I tried again with the NAS and it seems the problem is not any more a problem, I don’t know why when I tried the first time it didn’t work! so…we can consider it a workaround.
I have a question anyway, I’ve found a feature (maybe it was introduced from a while, but I noticed it only in the last couple of days) in the application 4stream: in audio setting you have a new “fade-in & fade-out” feature, promising to have no more problems switching from a song to another. I tried to set this feature, but I realized that if I enter again that menu, the feature is disabled again, I tried more times, it seems enabled, but anyway when I exit the menu and I check it again, the feature is disabled. Of course from USB I still have the problem of noises and interruptions from one song to the next one… Did you try? Any suggestion? thank you very much in advance. In the meantime I listen music from the NAS
I find that using my B50 SE my exFat formatted USB stick only plays the FLAC files, it skips the m4a files etc but it does show all files on the control app on my iPhone - why is this?
