Hi. I was using the S10 now for around 3 years on a 2.1 system feeding the subwoofer am, where the signal gets distributed to the satellites. This was working fine for me (damn single Bluetooth connection feature besides).
But now apparently it is not working anymore in the Wifi mode. As soon as I turn up the volume higher than 0, it produces a pumping and popping sound, so that my subwoofer strokes to the maximum back and forth with around 2 Hz. I immediately turned it off to not crash my woofer.
I took away the power and rebooted it once and had the same issue again. I didn’t try any other connection modes because I didn’t want to crash my speakers.
It sounds like a hardware problem to me.
Any advice? Are you familiar with such reports?
Greetings from Germany
Horst
