S10 Plus Optical IN?
Hello!
It is possible to change the optical output on S10+ to optical inpuit using ACP Workbench?
Regards
Otto
Hi Otto,
Nope, the hardware on device is optical receiver.
Not sure if I’m doing this right…how-ever I have an s10 plus that refuses to connect over Ethernet on a vlan phone is on the same vlan. So my question is does s10plus nic work if connected to a vlan?
Should be okay as long as devices are on the same VLAN.
