Hello,
I have ordered an amp2stream mono. It works perfectly except I have an issue.
We want to use your boards to stream our own stream (http/https link to our radio).
So I set my stream http link in services → OpenNetworkStream via the app 4Stream.It works.
The problem is when the app 4stream is closed or my phone disconnected from the wifi, the amp2stream finish always to stop streaming .
What we need exactly is:
After we setup the http/https link to our radio in the app:
Amp2stream must resume playing even if the app is not connected anymore or after a reboot or power-off.
Can you please tell me if this is possible and if yes witch settings should I use?
Is it via possible using the PlayLink API to resume the streaming if it is stopped?
Best regards.
