When using Tidal on the 4STREAM app with an A50+ it will skip through several tracks before playing. It is impossible to select a specific track and randomly plays after about 4-5 skips.
This started after the recent firmware update.
Any solutions?
Any solutions?
I have exactly the same problem of skipping tracks when playing Tidal
Last week encountered the same problem with exiting from the Tidal app with no reason. To avoid any future problems, you’d better use a music downloader, like ViWizard Tidal Music Converter, for offline listening.
meet the same issue ![]()
So, I seek ways to solve this problem.
I found the tool AudFree Tidal Music Converter. It helps save Tidal music to local device, then I can play Tidal music offline on my device without any issue.
Yeah, same thing happened to me after the update. Super annoying. It just skips through a bunch of Tidal tracks before randomly playing one. I couldn’t pick a song either, it was all over the place.
I tried restarting the app and the A50+, but it didn’t really fix much. Honestly, I got tired of dealing with it, so I started downloading my music instead. I’ve been using this tool called ViWizard Tidal Music Downloader. This app lets you download high-quality tracks from Tidal so you don’t have to deal with streaming issues.
I just load the music onto a USB or my phone and play it straight through the 4STREAM app without any skipping. Way smoother. Might be worth a try if you’re over the Tidal glitches.
