Just bought an Up2stream Pro V3. I would like to know the pinout for UART.
Founded but only for the previous version where the connector is at the rear of the IR receiver.
On the V3 there is not connector at this place.
Thanks
Thanks
you should be able to find it in the 11 pin connector, marked with TX and RX
…suitable near IR receiver at long edge of board
Thanks I forgot my glasses
to look and read the text under the board !!!
Community always can help You))))
