There are some fantastic Apps for controlling huge amounts of sound equipment using the OSC protocol (Open Sound Control Open Sound Control - Wikipedia).
It would be great if in addition to the proprietary HTTP REST API Arylic use, that they also had an option for OSC support.
Hi All,
I’ve found an Arduino library for OSC (OSC - Arduino Reference)
And I’m currently building a Control dashboard in TouchOSC | hexler.net
So I can control multiple Arylic Amps with a Ipad, using the Arduino to translate OSC into HTTP Rest API.
Hi @Adam_Anderson Adam. Welcome to the Forum, it’s a very friendly and supportive place
Thanks for your suggestions, I would certainly like to look into it.
Good Luck with your control dashboard, Kevin
