Hi everyone in the forum, this is my first message. Some weeks ago, after a long product selection work, I decided to purchase an S10. I’m really happy for the audio quality, knowing the limitations of native bitrate of the streaming services I’m using (Amazon Prime music + web radios), and for the product usage in general.
I order to cut off stand-by consumption from PSU and for a more comfortable “single button powering” of the system, I tried to supply the S10 from +5Vdc picked from the “dock” connector on my Yamaha R-S300 amplifier. I try to attach some photos.
Unfortunatly supplying the S10 from the amplifier dock connector I receive a noise floor, not so high but udible. This noise immediately disappear when I power using external PSU. It also seems to be not present if I power headphones at the S10 output, excluding the amplifier from the signal path.
I thought about a ground loop, or a difference between audio GND and 5Vcc GND.
What do you think about? do you thing the problem could be solved introducing an audio transformer on the output, whithout loosing on frequency response?
Really thanks,
bye Matteo
