Hi
I have what I believe is a very simple project that I can achieve with Arylic DYI products but need some help. I have a very simple outdoor pool setup that will have 4 speakers that I want divided into 2 zones/rooms. I want to play 2 speakers at one time, the other 2 at another time(or a separate audio source then the other 2 at the same time) or all 4 playing at the same time with a single audio source. The 4 speakers are outdoor speakers that aren’t powered so I would need an amp to drive them but can’t figure out what configuration I should create. Can anyone suggest the best option?
Thank you!
