Please confirm your 4stream App is the newest version.
Try Lan cable
Reboot your device
You can follow the instruction above to test first. If the issue still exist, please write your test consult to info@arylic.com and attach some related info:
-Your order number(If you are not buy from our official store, please offer the screenshot of your order. Who buy from the reseller or distributor please apply the replacement from your seller.)
-Device info
Input http://(replace your device IP)/httpapi.asp?command=getStatusEx to your browser. Please replace (replace your device IP) as your product device IP. You can find your device IP in device settings>device info<device IP
Then copy the info on the browser to us.
-Your app version
-If available, please send a video(with cloud link) about the noise sound to us.
I try to play bluetooth from my phone to either my Up2srtream HD or my A30.
Bluetooth works if I connect to either unit. The problem is when I try to use both. The unit I am not connected to drops out or looses sync.
The Up2stream is wired. The A30 is on Wifi and the app says the connection is 100%. My Wifi is Eero mesh routers and all of my devices work. Example: I can stream Netflix to my phone from the same location as the A30.
Up2stream HD Firmware: 4.6.414645.35
A30 Firmware: 4.6.415145.35
I have tried Restore Factory settings on both units multiple times. I have uninstalled and reinstalled the app (Android).
Ensure that both your Up2stream HD and A30 units are running the latest firmware versions available. Similarly, make sure your phone’s Bluetooth and related streaming apps are up to date. Outdated software can sometimes lead to compatibility issues.
Yes, 8 slaves would be the max normally. The major limit is the module performance, because it’s not implemented in multicast, so it will create a handling thread to transfer audio data for each client. This is the major limitation.
I have two separate A50+ units about 40 feet apart connected to the same WIFI router with excellent connection and internet speed. I am having issues with the audio either being very choppy or cutting out completely when trying to utilize the optical input from one of the A50+ units and trying to play it synchronously through both units. I have confirmed that both units are up to date on firmware and I don’t really have a way to connected them by LAN. Any suggestions?
