LP10: No LinkPlay? No Bluetooth source?
I love that the LP10 has AirPlay 2 and Google Cast, but the product page says:
:warning: Note: LP10 uses advanced streaming technology and does not support sync with other Arylic streaming devices by Arylic-native multiroom.
So there is no LinkPlay/sync, then? Or does it only apply when using AirPlay 2 or Google Cast as the media source?
Also, the product page doesn’t list Bluetooth under “Audio Input”. Will it not work as a BT receiver?
Example: Not all web pages or apps support Google Cast, and I’d like to use Bluetooth as a fall-back when necessary. Some old web radio stations lack Cast support, for example.
Example: I’d like to use Bluetooth from my phone to the LP10, and then be able to sync the audio to another S10+ with 4STREAM/LinkPlay. Will this work?
It’s non-Linkplay device and it does support Bluetooth.
Sadly, we have to migrate to other platform. So, you can’t use it as a master device and sync audio to other device like before. And you can get the multiroom feature through AirPlay and Google Cast.
When will the Qobuz Connect feature be available in the GO CONTROL app?
While 4Streams had it, LP10 should have Qobuz connect since it’s the newest product offering than S10+.
Hi, thanks for your interests. The Qobuz Connect feature would be implemented in device itself, not on APP. And we’re now working with Qobuz and Libre team, and will activate this feature via OTA upgrade. Currently, it’s under testing and certification, and will release after finished.
When could Qobuz connect be available on LP10?
Thanks
Nicola
Also hoping to see Qobuz connect via the S50 Pro+. I emailed Qobuz about it and they say they’re waiting on Arylic.
