Linkplay w/ Home Assistant
Hello,
New here…
I cannot seem to use the Up2Stream Amp with Home Assistant using LinkPlay (auto configured via discovery).
I configure it automatically with HA and I get the following error:
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:942
First occurred: 10:01:15 AM (9 occurrences)
Last logged: 10:02:33 AM
Update for media_player.living_room fails
Traceback (most recent call last):
File “/usr/local/lib/python3.12/site-packages/linkplay/utils.py”, line 46, in session_call_api
response = await session.get(url)
File “/usr/local/lib/python3.12/site-packages/aiohttp/client.py”, line 659, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 557, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1002, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1305, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/local/lib/python3.12/site-packages/aiohttp/connector.py”, line 1061, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 82, in start_connection
sock = await _connect_sock(
File “/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py”, line 174, in _connect_sock
await loop.sock_connect(sock, address)
File “/usr/local/lib/python3.12/asyncio/selector_events.py”, line 641, in sock_connect
return await fut
asyncio.exceptions.CancelledError
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.12/site-packages/linkplay/utils.py”, line 45, in session_call_api
async with async_timeout.timeout(API_TIMEOUT):
File “/usr/local/lib/python3.12/site-packages/async_timeout/init.py”, line 141, in aexit
self._do_exit(exc_type)
File “/usr/local/lib/python3.12/site-packages/async_timeout/init.py”, line 228, in _do_exit
raise asyncio.TimeoutError
TimeoutError
The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/linkplay/media_player.py”, line 149, in _wrap
return await func(self, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/linkplay/media_player.py”, line 198, in async_update
await self._bridge.player.update_status()
File “/usr/local/lib/python3.12/site-packages/linkplay/bridge.py”, line 93, in update_status
properties: dict[PlayerAttribute, str] = await self.bridge.json_request(
File “/usr/local/lib/python3.12/site-packages/linkplay/bridge.py”, line 288, in json_request
response = await self.endpoint.json_request(command)
File “/usr/local/lib/python3.12/site-packages/linkplay/endpoint.py”, line 51, in json_request
return await session_call_api_json(self._endpoint, self._session, command)
File “/usr/local/lib/python3.12/site-packages/linkplay/utils.py”, line 65, in session_call_api_json
result = await session_call_api(endpoint, session, command)
File “/usr/local/lib/python3.12/site-packages/linkplay/utils.py”, line 49, in session_call_api
raise LinkPlayRequestException(
linkplay.exceptions.LinkPlayRequestException: error requesting data from ‘https://192.168.15.29/httpapi.asp?command=getPlayerStatusEx’
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 942, in async_update_ha_state
await self.async_device_update()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1300, in async_device_update
await self.async_update()
File “/usr/src/homeassistant/homeassistant/components/linkplay/media_player.py”, line 151, in _wrap
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Exception occurred when communicating with API <function LinkPlayMediaPlayerEntity.async_update at 0x7f34dab39c60>: error requesting data from ‘https://192.168.15.29/httpapi.asp?command=getPlayerStatusEx’
It seems that the HA is trying on HTTPS but I assume the Arylic doesn’t respond on HTTPS but HTTP. Can someone please confirm what needs to be done to get this working in Home Assistant, this was the main reason I bought this device. Does the firmware on the Up2Stream Amp needs to be updated to support HTTPS???
Please help
this won’t fully help, but i just set up my 2.1 amp via auto discovery in homeassistant with no obvious errors like you have.
there does seem to be an issue with the controls not really working though (play/pause/skip) but volume, input select, EQ etc all seem to work and it displays the current content.
So seems like something else is going on with your system. LMK if there is anything you want me to check on my setup for comparison.
I ended installing Music Assistant and via the DLNA provider within it, add the Arylic. It’s seems to work a little better with my Jellyfin music collection. More specifically I also wanted announcements to play while pause/playing the background music. I seem to have better luck with this than I ever did with configuring Linkplay directly in HA. Not sure if this is best advisable setup and hoped to get Linkplay working.
Discovered linkplay yesterday and just came back here to mention it… You beat me to it! Seems like a pretty good solution.
