Is it possible to connect the lcd panel to the up2stream amp? I need to see what a music is played. Maybe some of colegue made that projects>?
look this:
https://forum.arylic.com/t/my-project-with-up2stream-pro-v3/1277/12
no lcd, but You can write your own sketch with any kind of display
Thx for answer. It looks ok. But iut’s need arduino or RPI for that porojects. I need to make project with similiar panel like this:
But I know it is need to use some arduino or rpi.
Personally I would chose RPI and Python for this route. I have heard good stories about PyQt, although never tried it myself.
https://riverbankcomputing.com/software/pyqt/intro
If you google around I would use the UPnP/DLNA method as I am pretty sure this supports all track metadata (including Album Art)
Hope this helps, Kevin
Ok. I think too about raspbery - it’s better idea for my questuons
thx.if I do projwcts I will show on this foeum.
This was written for the WiiM Mini, but should work with Arylic products, which are also based on Linkplay modules. Might require some mods for missing info…
