Hi, some days now all my 1 - 10 internet radio stations fail to play. When I try to find a new station in browse/Internet Radio there are zero stations listet. Am I alone with that issue? Still working is stream URL in the browse/Open Network Stream compartment. My devices are Up2Stream Amp, Up2Stream Mini, and others. Thank you!
Same problem over here. But only with android, It seems a problem with android because iphone is working oke.
Same problem for me ( belgium & android / S50pro+ )
@biky I have the same problem, that’s why I wrote here earlier how important it would be for the device to remain independent of these third-party services, one of them thinks about it and terminates the service, and then the device manufacturer opens its arms - and then you can throw away your expensive device to the garbage…
The problem looks global, maybe the WiiM forum is more informative: vTuner no longer works? | WiiM
It is most likely something in the internet radio of the 4STREAM android app. As a (temporary?) solution, I now have the legacy player app (previously Muzo player) with Tune-in and it works perfectly. Hopefully there will be an update soon.
The fault has now been resolved and everything is working perfectly again. It seems there was a problem in internet radio (vtuner). We are happy that everything is working properly again.
same here, I am happy about it! If internet radio is not working, all my Arylic products are quite useless for me.
Hello, i’ve reseted my S50pro+, uninstaled the 4stream apk, then make the installation from zero for the box and the apk, and all came back to normal and works perfectly … even “inernet radio’s” works well
Have a nice day
Denis
Hello, i’ve reseted my S50pro+, uninstaled the 4stream apk, then make the installation from zero for the box and the apk, and all came appsback to normal and works perfectly … even “inernet radio’s” works well
Same here, Internet Radio is dead, no presets working, no internet radio stations found anymore.
Complete uninstall and install will erase all presets and favourites…would be nice if ARYLIC will find a solution…
I did some reverse engineering apk and found a URL where all the radio stations it reads are, but I don’t know who can update the database of the radio stations service?
https:// balkanradiostanice .com/bazasqlitespremnazip/dbdown-v3.zip
