As in the title…
In the Go Control app, what does “dual output” mean?
It does not seem to do anything? (in the B50 amplifier)
Hi Rene,
Sounds to me like you can use the app to control audio on multiple Bluetooth devices.
Hi Rene,
It’s meant to enable the device output itself while connected to Bluetooth speaker with TX.
By default the device will be muted, and if you activate this “Dual Outout”, the device itself will also have audio output, though the output will not sync with the Bluetooth speaker
Thanks for the explanation! However, enabling dual output does not activate the amplifier itself… so it must be something other?
