I want to build a stereo pair with two Up2Stream V4 boards. One Up2Stream V4 is connected to a right speaker that has two drivers: the left channel drives the bass (low-pass), and the right channel drives the tweeter (high-pass).
The right speaker itself has its own Up2Stream V4, also connected to two drivers (low-pass and high-pass).
Which settings do I need to configure to get a true stereo setup?
How exactly should I configure everything in ACPWorkbench? Could someone please post a screenshot of the settings?
Your idea crops up now and again on this forum using various boards and configurations.
To explain, these components were originally created for multi-room setups where there can be some (hardly noticeable) latency or delay between rooms, this latency would be more apparent in a single room left - right channel situation.
I’m not sure if any forum members have successfully demonstrated this is successful but I’m just giving you a heads up of potential problems.
