Hy to all, is there a possibility to rename the Bluetooth name of the device (not when you name it dining room or etc.) but when chose BT connection and have more then 1 device in vicinity of the same type.
it’s hard to guess witch one is the one when all have the BT name soundsystem ) iven if in the app all are named by room or location.
I also encountered the same problem, have you solved it?
