please leave your views.
Happy to, but which? Any particular, or in general?
I haven’t purchased those particular items, but from what I have purchased I am very pleased with.
It’s a very good multi room system, it appears to be well designed and it’s easy to set up and configure.
You can input pretty much any audio source into the units and can get them to play separately or linked to play the same source.
The control app has many features and is easy to use.
I haven’t purchased any of the Arylic amplifiers, but I have been told that they work well and are compatible with almost any speakers.
I hope this helps make up your mind?
