After few Factory resets the SSID still remaining and don’t know how to change it. It contains my name
and I want to change it.
Same problem here. Some of the amps change SSID according to freshly set name after reboot / factory reset. Some stays the same.
Help would be appreciated. @zpl1025
http://$ReceiverIpAddress/httpapi.asp?command=setSSID:value
1:Value is the name,put yours name
2:Receiveripaddres-put your player ip and hit enter in adress bar
thnx ![]()
