I need it for some calculations before I buy it.
Just in case you mean the “Plate 2.1” version, I took the following measurements at mine:
Height: 134mm
Width: 149mm
Depth: 40,5mm (including plate; plate thickness is 3mm)
If you mean the “non 2.1” Plate (that is a 2.0 amplifier with integrated power supply), then I do not have the measurements. I had one in my hands a couple of weeks ago but its no longer in my posession. As far as I remember, the depth was larger than the one of the 2.1 Plate due to the power supply.
Regards, Sven
Thanks for the reply, Sven.
Its the non 2.1. The dimensions of the amp are available online but if I calculate the volume like a cuboid there is some air space that is wasted since it is shaped like an L. So what I did was halving that cuboid volume, which comes up to 450 cm2. I don’t know if that is right though.
450 cm2 sounds like a reasonable upper limit. Considering that the part of the device that goes into the box is smaller than the plate it should be more towards 300-350 cm2.
May I ask for the reason you need the correct volume?
Regards, Sven
