This article summarizes the changes for specific Models A30+ , SA100 , WBC65 , and Up2stream Plate Amp firmware release on May 11.2022.
Newest Firmware Version
- A30+/ 4.6.415145.29
- SA100/4.6.415145.29
- WBC65/4.6.415145.33
- Up2stream Plate Amp/ 4.6.415145.30
New Features:
- Add preset EQ, Flat/Classic/Pop/Rock/Jazz/Vocal
- Support gapless playback
- http API for playing notification
httpapi.asp?command=playPromptUrl:[URL]
- Fixed, HTTP API reboot not working
- Adjusted default volume step to 5
- Adjusted minimum MXV to 30
- Add extra IR code for power on and power off
- Will reboot the device and enter WIFI mode when the sleep timer is out, to avoid the system not responding on standby.
- Add -BLE appendix for BLE device name to distinguish with classic Bluetooth
- Sync VB settings when set in ACPWorkbench
- Fixed, can’t switch to LINE-IN mode on boot
- Fixed, connected BT device is not forgotten when factory reset
- Fixed, used treble value for bass on boot
- Fixed, system detected silence when the input level is low
- Will set volume of AMP for master volume to improve the noise(WBC65 Only)
Web Player New Features:
- Personal Radio
- Audio Settings
- Need a password for the whole page
- Set title for the page
