Hi. This is a great update. especially pleased with the “HTTP API for playing notification” feature. For my purposes, this feature is very useful, but I would like to have the ability to completely turn off the sound when the notification is turned on. Is it possible to implement this?
Will this feature be available soon on the S10? And I would like to know when the update of the 4Stream application is planned.
Hi @LVH , glad to hear that our feature is helpful.
Currently, when the notification is on the background music volume will lower. Similar to phone coming with the notification right now.
You know sometimes people have different point on some features
I already report your needs to our system, we will check and collect more figures.
Then we will apply the feature once we found that is more compatible to the user experience.
And yes, S10 will release the new firmware soon.
About the 4Stream app,
Thanks for your time to give us the nice feedback!
I completely agree with different points of view. And I’m sure many will disagree with me. but for my tasks it will be a very convenient solution. why not add such a setting to web or acp? thanks for your feedback and for what you do;)
Hi there!
I have had a A50+ in addition to three Up2stream Pro V3’s for over a year now. After the most recent firmware update I’m experiencing the same issue as Jimi, the A50+ frequently looses the Wifi connection and it is quite a struggle to get it to reconnect. It takes anywhere between 3 and 10! tries to finally connect even though the wifi reception shows four bars.
Prior to the firmware update this did not happen at all and I am not seeing this issue with aV3’s at all even though some of them are further from my wifi router.
Is this a known issue?
Othere than that I have to say thanks for the great work Arylic team!
Concerning my wifi problem it’s better now (i did a factory reset). It append still but not as much as before, as i have a mesh network with 2 routers in a 50 sq meters flat i think sometimes the a50+ connected to the far router and it’s crew up the connection.
@Joy i got a new firmware version onto my A50+ device today, its version number is: 4.6.415145.41 (build date: 20220427). May It know what changes it contains?
