Hi all,
how I can connect the external reset button on the v4 amp? On the board I see one pin for external reset button, but where I connect the other pin?
Hi all,
Not very clear, is it? I would assume that seeing as though the pins for the LED extensions and for the external buttons go to the VDD3V3 that the reset would be the same?
It would probably be wise to ask customer support though.
You should install PushButton between RESET to GND
Tested and it works
