Hi, when i use internetradio tuneln i do not see the current song information, is there a way to change that?
Regards Frank
Maybe i was not clear as i got no feedback.
Do you have the same behavior, when i start tunnel radio, i get an information at my screen, that never changes. I expect to get the current title and interpret.
Am i wrong, is that my fault, or a bug.
Regards Frank
I’m sure it’s a software issue.
Strange, that no one else has an problem with that, for me this is essential, what can i do to get that fixed ?
@Frank Frank,
I am not an expert on these things but I do half a clue
I “imagine” that the track information depends not solely on the Arylic / Linkplay Software. It also is very dependent on the Service (vTuner, TuneIn, etc.) What is tunnel radio ?
In Summary Points of Failure could be
- Internet Radio Service is not broadcasting Track Information
- Linkplay/Arylic are not detecting the track information
- 4STREAM APP is not displaying track information on change.
If you can be patient I will check out “TuneIn” behaviour at this level. I don’t use use TuneIn so I just need some confirmation on your side before investigating.
- You are using TuneIn ?
- What Arylic Device do you have ?
- What is your Visual Display, Phone ? Android ? Apple ? 4STREAM APP ?
- Which Internet Radio Stations are you listening to ?
Regards
Kevin
Hello
Yes w - What Arylic Device do you have ?
I have an Amp v4 - What is your Visual Display, Phone ? Android ? Apple ? 4STREAM APP ?
I use 4stream on ipad - Which Internet Radio Stations are you listening to ?
E.g. Antenne Bayern
Thanks frank
@Frank got the info
Will look into it
There is a distinct difference between “no-one has” and “no-one complains about”
I myself have the same problem but I have come to live with it.
A solution would be nice however ;-))
Frank,
For some reason there was no content this morning on Antenne Bayern.
Without getting into the details of how I tested this
- When testing radio stations in TuneIn there are many stations that do not provide track info.
I am thinking the most common fault is that Broadcasters register with TuneIn but don’t necessarily set up things perfectly following TuneIn guidelines. See Link
I would suggest the first place to start is to ask the Broadcaster if they comply with the TuneIn Guidelines.
Hope this helps
Kevin
Thank you Kevin for that Information,
Is there an other way or app, in arylic, to get any Internetradio with song Information.
Regards Frank
OK Frank
I have only recently found out how dlna works. This is the key to doing this together with the Arylic.
I still need to get my head round it all. Will do some research and get back to you.
Kevin
Hi Kevin,
Do you have news to that.
Maybe you know a releasedate .
Thank you, Frank
Hi Frank,
Suddenly I have a bit more time to do this sort of stuff.
I’ll look into it again and make some firm conclusions.
Should be able to do this this week.
Regards, Kevin
Just a note: in the case of internet radio streams, the artist - song title does not appear on the web interface (and in 4Stream app), the same stream e.g. displays tags when played in Winamp.
Hi arylic,
Slowly i get a little dissapointed how long it takes to get that feature request. Bye the way. In my oppinion this is a basic feature, like a steering wheel in a car.
Al the other players like volumio or hifiberry provide that oob
Regards Frank
