Critical connection issues to BP50 from Android 15 devices
I own to Android smartphones: Xiaomi 13 and Sony Xperia 1 VI.
For the 1st time, the Xiaomi 13 connects well to the BP50. Then, if I deconnect the phone and then try to reconnect, it doesn’t work well: it connects, disconnects, connects, disconnects indefinitely… I have to reboot the phone to get a stable connection.
Regarding the Xperia 1 VI, whatever I do, it it connects, disconnects, indefinitely…
My phones are up to date and my BP50 has the latest firmware (Android 15).
Is my BP50 defective? Seems like a software issue?
Any tips?
Thanks for the help.
[Update] list of bluetooth audio receivers tested by me that work/don’t work on latest versions of Android 15:
  • Dacia Sandero Stepway 2 - bluetooth ?.? (2017): OK
  • 1Mii B06HD - bluetooth 5.1 (2019): OK
  • 1Mii B06HD+ - bluetooth 5.1 (2022): not OK
  • Fiio BTR7 - bluetooth 5.1 (2022): OK
  • Fiio BR13 - bluetooth 5.1 (2023): OK
  • Arylic BP50 - bluetooth 5.2 (2024): not OK in RX mode
I suspect that the issue is not only due to Android 15 but also to some manufacturers that don’t respect some bluetooth specifications… (to be investigated)
"Android 15 devices are experiencing critical connection issues with the BP50. We’re investigating the cause and will share updates soon. Thanks for your patience.
Any news? Firmware update soon?
