Hi all,
I am currently working on a couple projects that consist mostly of Bluetooth party speakers. Pretty much all of these projects use the AP82xx chipset from MVSILICON.
I am using ACPWorkbench to set the DSP settings on the speakers and I can easily get the speakers to perform the way I want, but with the computer connected to the speaker.
The problem is that I can’t run the units stand-alone without a firmware update, which usually comes as a *.MVA file.
Would there be any tools that would allow me to convert /compile my *.ini or *.c files exported from ACPWorkbench into a *.MVA update file ?
Any help/insight would be greatly appreciated.
Thanks
