Hey guys.
I am using arylic up2stream pro v3, the spdif-input extension and the DAC-board.
How can i change between coaxial in and optical in? Is it possible to change between both inputs or do i need to choose one between both?
Tnx!
-Chris
Hey guys.
Tnx!
-Chris
Hi Chris, only one at a time as there is no way to internally switch.
I think from memory that that if you plug both in that the optical overrides the coaxial.
Steve
Hey Steve!
Thanks for answer and for this information. That helped me a lot and makes sense!
Chris
