Cant send commands bei UART - Up2stream pro V3
Hey Guys!
I am trying since some time with an Up2Stream pro v3. I love this device, and since yesterday i am playing with the UART-commands.
I can receive the commands which the V3 sends very well, like when it is booting, changing the source by button or in NET-mode sending the track information.
But unfortunately i cand send commands to the V3.
I am using a small CP2102 USB-UART converter connected to the RX/TX-pins of the V3. Receiving works well. When i connect RX and TX of the CP2102 i can see what i write in the command line (PuTTY).
But when i write commmands like STA; or VER; or even SRC:BT; nothing happens.
Configs in Putty are 115200baud,8,N,1, no flow control.
Can you please help me or give me some clues where i made my mistake?
Thanks!
Best greetings and 73,
Chris DC2SV
I was still trying, when i send the commands with the serial monitor of the Arduino environment, it works fine.
So, actually it seems like its a problem of Putty.
Hi , i know it was a long time ago but would you have any arduino code i could see (that would get me started ) as i only have limited arduino programming knowledge but would like to be able to switch the up2stream V3 pro into BT mode at the press of a arduino connected button . Thanks
