I am not able to pair and connect more phones to the B50. Connected two phones when I got it, and they work but when I try to pair other phones now I just get an error message “can’t connect”. Just to be clear, I am not talking about connecting phones at the same time, but be able to used more phones with the B50. have tried 5 different phones of different brands, Motorola, OnePlus and Nokia. None will pair and connect. I have also tried to connect those phones to other Bluetooth devices and it works fine. What could be wrong? I updated the fiirmware but that didn’t help either.
Before you want to connect to B50, does the blue LED blinking fast? which means the device is in pairing mode. If not, you need to trigger it with pressing the button once on rear side.
And one more point, the Android system will list all BLE device and Bluetooth Audio device in the same list, could note for the icons in front. Normally the audio device is with headset or speaker icon.
could you please add the command for pairing in the API?
My arylic device is mounted in the attic of my garage and it’s not easy to get thre to press the button…
Hi Epix, we’re preparing a release of new Go Control APP, and it will support to query and set network without touch the device.
Great!!!
I am having problems connecting my phone and music player to the B50. I used to be able to connect my devices to the B50 to stream music, but I hadn’t used it for a while and now I can’t get anything to connect. I only see B50-BLE in the devices list. I can connect to the Go app, and everything else works fine.
I’ve tried powering off, updated the firmware but no joy.
When in bluetooth receive mode the blue light is blinking slowly. If I press the button on the back once it continues to blink slowly, if I long press it then it blinks faster and then resets. Am I doing it wrong or is there an issue??
Hello. I have the same problem with my B50. Did you found perfect solution? Please help me!
I have the same problem with bp50
