Is it possible?
To use only the Input/DSP part and hook it up to the amplifier of my choice?
/JZ
Is it possible?
/JZ
Probably, if you could identify where to break it out.
Why not buy a mini or pro board though? They cost very little and you don’t risk stuffing up your 2.1!
That would be great if they only hade support for the .1 channel. (Subwoofer)
As far as I can understand they on have 2 channel.s.
/JZ
Easy if you have an active sub.
