Hi there!
Disclaimer: I don’t know anything about this device, I’m just trying to help my S.O. with the firmware update due to several bugs. ;D
So I formatted a flashdrive and copied the unzipped firmware file on it, plugged it into the BP50, doubleclicked the wheel/button.
In the app there’s now the notification that a new firmware version is found on the flashdrive, if I want to update it. So far, so good.
But when I confirm the only thing that happens is all LEDs flash up for half a second, than the red standby LED flashes and then USB.
Nothing gets updated and oftentimes the app then disconnects.
I am having the same issue trying to update from firmware 55-e12492a2-8 to 56-0bf6cc3e-20240130; freshly formatted drive with only the MVA file at the root. I get the prompt to update, tap “Confirm”, then the unit reboots. Reloading the app, it still reads version 55.
The only thing I want fixed in firmware is the analog line output randomly turning off… everything else works great for my purposes! Hopefully this gets solved.
The Line-out randomly turning off? Maybe you could check the connecting wire and see if it’s loosen or broken somewhere. The device will not have this kind of issue for sure.
Sure thing, to be specific it’s a TCL 65R646 and I’m getting audio via optical out.
I have some other notes about the line outs cutting off, but I don’t want to hijack your topic so I’ll put them in another thread… but I can guarantee it’s not loose cables!
