Did you end up getting this working? I’m looking at doing a similar setup with LG C9 + Nvidia Shield 2019 + Arylic B50. What specific CEC issues are you experiencing?
Im pretty sure my TV is the problem, but I don’t know if its a LG thing in general, or just the age of my TV.
Power on/off: Using the shield remote via bluetooth (default behavior) with CEC just doesn’t work for my TV. The shield turns off but the amp and tv remain on.
Vol control: Using shield remote via bluetooth with CEC doesn’t work, unless I force HDCP 1.4 in the shield developer options. This is the main reason why I suspect its the TV.
If I tell the shield remote to use IR for power on/off then I can control my TV, which in turn triggers the amp to turn off*.
*The amp won’t turn off if it ever receives a cec volume request. I don’t know why.
If I request power on/off a few times back to back then it eventually gets the message and actually turns off.
The amp always turns on correctly, after a 5s delay, so that good at least.
My best guess is that the tv doesn’t respect cec commands from the shield. Commands originating from the TV via IR appear to work though. Ie: the TV wants to be the CEC master device.
PS: I’ve read many posts on reddit where people have CEC issues with their brand new, expensive, LG C2/C3 OLED tvs. It seems that LG have some CEC challenges.
Is your Nvidia Shield able to control the internal LG TV speaker audio via CEC? I can’t get that to work correctly on my LG C9 and have to rely on IR controls. As such, I suspect all LG TVs will have issues with the B50. Sucks.
I’ve not tried to control the TVs speaker via shield driven CEC, but I suspect you can get it work if you force HDCP 1.4 in the shields developer settings.
I ended up getting the Arylic B50 and fortunately both HDMI CEC volume control and standby work out of the box with my LG C9 and Nvidia Shield remote without any special configuration. B50 on my HDMI ARC port, Nvidia Shield on another non HDMI ARC port. TV set to output HDMI ARC as PCM with Simplink enabled. HDMI-CEC and Volume control enabled in the Shield settings. No developer options enabled. Phew!
Quick question: did you notice any audio crackling or artifacts during your testing? I swear I’m hitting an inconsistent crackling in audio or video playback that I can’t consistently reproduce.
Related: how did you configure these audio options in your Nvidia Shield?
Available formats
This should be none/no surround I think to force stereo down mixing
Stereo upmix
Not useful for the B50
Dolby audio processing
I think we should enable this for compatibility because the B50 doesn’t support DD+?
Play comfort noise on HDMI
User choice, maybe helpful to keep hardware responsive when waking up from standby?
Match Dolby/PCM audio levels
User choice, will lower volume but make volume consistent across apps?
Match content audio resolution
User choice, helpful for some music streaming apps with different encoding?
Yup, same story here. Nvidia Shield → HDMI 2 in TV > Philips 49PUS6561/12 → HDMI 3 in TV > B50. There are either cracking noises or random jumps in volume level during volume change (tested with 57 software). Those noises are not happening in BT mode, no matter if I change volume, song etc.
@joia@zpl1025 this is the issue I mentioned in other thread.
