Hello,
I bought an Arylic S50 Pro + and after I connected it I tried USB stick and the USB memory is no longer visible when the player is turned off and on again.
But when I pull it out (USB memory stick) and plug it in again, the device sees it. And every time I turn player on, the same problem occurs.
Question: Is it a design feature that needs to be done every time or a software bug?
Thanks for the help in advance
