Arylic IR Remote Code Database
Is the Arylic IR remote in Kookong code database? If so, it is listed as Arylic? If not, is there another remote brand I can select to use with Arylic products?
I’m pretty sure the IR remote I purchased from Arylic is faulty as it seems to work intermittently so I am troubleshooting it. When I manually program each key into a Logitech Harmony 650 all-in-one remote, it takes several attempts. Then when I use the Harmony with the amp it works great.
If the Arylic remote is in the database, perhaps as another brand, programming would be so much easier.
I have a Sofabaton remote that works with my Arylic LP10. If I recall correctly, the LP10 wasn’t in the database when I set it up, but choosing a different Arylic device worked fine.
Hi, you could refer to the raw codes here: User Manuals |
