Purchased 6 WBC 65 $$$$ and they still do not connect and I have not received support. I suggest that at this time do not buy this speaker that is defined a wireless. The manual is not accurate. I am in the USA.
I bought 12 pcs in total. Every single one is just working fine 100%. I also have other products from them all working like they should.
So if you have technical issues do to incompatibility or missing knowledge you should not wright just “Do not buy”!
Special if you do not describe your problem here at all as the first point for support is the forum.
For sure its just a stupid problem and fixed in seconds…
So I can recommend this speakers 100%, do not listen to this unusefull rating…
