Arylic A30+ /A50+ Automatic resume after power cut
At the moment I have a Eissound module that powers 2 small speakers in my shower. The Eissound is connected to a remote control power socket. When i give the command to enable the power socket the Eissound module starts playing.
The reason I want to switch to a A30+ or A50+ is because my Eissound only works with FM and reception is mostly very poor. Thats the reason I want to switch to a module with Wifi/Lan to play internetradio.
Now my question is does the A30+ and A50+ automatic resume playing after a power cut (from the remote controlled power socket) or can this option be enabled? I could use the included remote I hear you say but the module is tucked away in the ceiling and sadly it uses IR instead of RF so the included remote will not work I guess.
Thanks for your reply!
Wes
