I’ve been very much enjoying working with these products, starting with the up2stream pro v1, now really enjoying what i can do with the AMP 2.1
I’m trying to write a translator to take an REW EQ text file (default format)… so far, so good.
some issues… the freq value in the exported EQ file (from right clicking in the eq graph window) appears as in the APC workbench UI, but the gain and q are different values.
In the workbench UI,
freq = 169
gain = -7.4
q = 2.546
I can get really close by:
gain =round(float(gain)*256)
q = round(float(q)*1024)
The numbers i get almost always the same or off by 1.
Still, when i import the EQ ini file that i create, nothing appears to happen.
It appears that the “reserved” value seems to specify something about what EQ is being updated? If this is a new EQ (it is, as I’m making a new one from the REW output), what should i specify for the reserved value?
I also note that when I create an export file from the APCWorkbench UI, it apparently mis-spells “filter2_gain” as “fi lter2_gain”… is this an issue?
Hi, I’ve missed this topic! You’ve done a great job, did you get it working now? For the gain and Q, I think you have the formula, and if it’s off by 1, maybe plus one in the calculation.
And for the filter2_gain, please keep the wrong spelling in the format… and I think you might only be interested in the EQ part, you can just reserve the headers without value to avoid affect the other settings, but the user defined effect is still needed, and seems the configs does not take effect…
And because each product might have different param list, still need to prepare some template to handle with program.
This is a sample I’ve tested imported OK on AMP2.1
I will try your suggestions tomorrow and see. Thank you so much!
This is a very handy piece of hardware (the 2.1) is there any possibility of more than just eq? some options for delay or other transformations would be very helpful.
It’s possible to add some small delay between channels, eg 100ms, as it only have some KB memory inside. Maybe it could be used to fine tune the phase.
