Anyone get UpStream DAC to work with Roon?
Roon discovers my Upstreams but won’t play to them. A few seconds after processing play it stops in the app but no sound ever came out.
Yes, UpStream DAC works with Roon, but you might need to enable it in Roon’s audio settings. Make sure it’s recognized as a network or USB DAC, and check RAAT compatibility. What issues are you running into?
Yes most USB DACs (like UpStream DAC) work with Roon via USB, even if they’re not Roon‑Ready devices. In Roon’s Settings → Audio, just enable it under the USB/Connected Outputs section It’ll appear as a zone and support bit-perfect playback (RAAT exclusive mode) no need for certifications or network streaming setup.
We’ve had success connecting roon with our up2stream devices through airplay.
