Any plans of making ACP Workbench compatible with Up2Stream HD DAC
Are there plans of making the Up2Stream HD DAC compatible with ACP Workbench Tuning Tool? AFAIK, ACP Workbench doesn’t work with Up2Stream HD DAC as the USB-C port is power only (no data).
The inability of using the ACP Workbench on the Up2Stream HD DAC is a strange implementation in my opinion.
eh… we’re also wanting to support the DSP tool, but for HDDAC, it’s designed with working on a various sample rate from 44.1K to 192K which will respect the original sample rate of music file. The ACP tool is working with the DSP which is working in fixed 44.1K or 48K sample rate.
I need help trying to the same as Deibelist stated earlier
ACP Workbench doesn’t work with Up2Stream HD DAC as the USB-C port is for power and no other usb port available to interface with workbench. Thanks
i try searching and this is all i found.
