I suggest to add a function to show the bit rate of the input source and the output from Arylic devices.
@Paul_Rumyee Hi, It doesn’t really matter because the output dac always converts to 44.1kHz / 16bit.
So if I used an external DAC by using Toslink that should improve the bit rate, please confirm.
@Paul_Rumyee unfortunately not, the digital output only displays the signal with the downsampled bit rate and bit depth (so you can only feed the external DAC with it…)
