I own an Apm 2.0 V4 and ACP Workbench (Win 10).
When i change settings in ACPWorkbench i use “Download → Save Configuration to flash” (Group 0).
After Power off and on all my settings are gone.
I dont use Virtuall Bass.
I only use EQ settings but it wont save.
I also encountered this. I found out by experience that after the last firmware update, group 4 is working in the device by default. This happened on both of my devices. Try saving to group 4. I figured this out by saving the data in a row to all groups from 1 to 6. If you have a remote control, then groups can be switched by long pressing the numbers 1-6.
Arylic promised to fix this in the next firmware version.
Hi Irek,
I have now simply saved the settings in groups 0-4 (one after the other). And it was saved.
You are my hero of the day :-).
Thank you very much.
And yes, I have the remote and will test the days which group belongs to which key.
