Hello,
over the last years everything works fine, but after the last updates, ACP/Up2Stream Amp 2.1 are loosing the settings.
If I run ACP (Version 2.21.0) the settings got back to default. Loading my saved audio settings is no possible (the connection between ACP und Amp ist okay).
I always get the error message by import my audio settings: “Import Registers Data - User defined effect should not be imported”
Here is the part from the import file:
[0x90-User-defined_Effect]
enable = 1
Mode = 0
LR Swap = 0
[0x91-User-defined_Effect]
enable = 1
Function = 0
[0x92-User-defined_Effect]
enable = 1
Function = 0
[0x93-User-defined_Effect]
enable = 1
Function = 0
What does that mean, any solution?
The second error is that the amp is not saving any audio effects. If it will be conntected to ACP, I always start at zero.
There is no chance to get the settings in the Amp, quite frustrating at the moment
MANY THANKS
