ACP Workbench newest version
I have version 2.21.14 which seems to be from 2020. Please let me know how to get updates for ACPWorkbench.
Some details: I have seen the “Music Delay” functionlity in screenshots on the respective Arylic webpage. I need this functionality for proper subwoofer integration (delay main speakers for better timing with a sub). I am in contact with support already, but did not get the correct link to the latest version, yet.
Is there no place to download?
@bixite there are some newer versions here, check it out: https://www.reddit.com/user/jojo9092/comments/13d3pxj/dsp_software_download_for_mvsilicon_nvarcher_amp/
Thanks for the information. These are links from archive.org and it is not possible to judge if these are reliable downloads and it also does not claim that it works with Arylic. For security reasons, I would rather like to have a download link from Arylic to get the latest version. So far the support was not able to supply that … I will try again.
@bixite as you can imagine, I use it with satisfaction (full-fledged software for the same dsp chip.)…
Sadly, there is no support from Arylic for an updated version with bug fixes etc. Which of the two versions you mentioned do you actually use?
@bixite download both (if you can at all) and use the one that suits your purpose!
