Unfortunately app TuneIn doesn’t sound - no play, but:
- it show radio cover
- other app Internet radio works perfect but it has not cover radio
do other users have it too?
is there any solution to this?
@jomziom exactly which station do you have a problem with? Does the same stream work normally when opened in the android TuneIn app?
yes and no, when I try open Radio 357 station over TuneIn i receive promp that cannot be opened
But when I play via Internet Radio menu it play perfectly but no cover ![]()
I think the problem will be more with TuneIn. I haven’t used it in a long time, I have my own collection of links, along with cover images.
hm, strange situation - I also checked on my wife’s phone and it also does not work, but on the pc I still listen to the same stations and they work.
Can You check exactly the same station on Your apps? radio 357
This station is also available on my phone and via the 4Stream app in TuneIn (despite geolocation filtering (I’m in Hungary)).
Here are the two stream links of Radio357, try to insert it in webplayer’s url play…
Format AAC:
https://stream.rcs.revma.com/ye5kghkgcm0uv
Format MP3:
https://stream.rcs.revma.com/an1ugyygzk8uv
in webplayer works everythings, but problem is only in dedicated TuneIn apps
ok, I still think the problem is with TuneIn itself.
but over tunein web page pays ok :-))) so it could be some API tunein problem or 4stream…
Since the stream started fine on both surfaces for me, I wouldn’t think so. Maybe some local network restriction…
I’d like to hook into this thread, because I am experiencing something similar.
This is my situation.
Speakers setup
I have 3 speakers, devided over two rooms. All based on the Up2Stream Mini. Two are in a living room (grouped as a stereo set), the other one is in a kitchen.
What happens
When using Spotify: everything works well on all speakers in each room. Streams always start smoothly.
When using TuneIn: the speakers in the living room work well, but the speaker in the kitchen doesn’t; 5 out of 10 times, the stream from TuneIn does not start.
Additional
To be complete, the indication for WiFi signal strength as shown by 4Stream App is 100% for the speakers in the living room and 42% in the kitchen.
My first thought of course is that 42% is too low and the cause of the problem. But on the other hand, Spotify has no issues the start streams on this ‘weak’ signal, it always starts without any problem.
Question
