A50+ Audio Prompts Language setting -> Off/None?
I have a problem with periodic loud “Entering setup mode” announcements from my A50+ whenever my bricked router does auto wifi band management and the A50+ connection drops momentarily. (To use a static IP address would solve this but it is not possible with my router unless I put it in bridge mode and manually manage all device connections and relays, very annoying!) So I’m looking for a solution on the Arylic side. Other than turning the device off during the night I think being able to turn off the Audio Prompts or select language = none would solve my problem. Is this possible or could it be a new feature? Current language choices on my unit are English or Chinese.
thanks for any help with this!
Yes, it is possible to turn off audio prompt through httpapi:
http://192.168.x.y/httpapi.asp?command=PromptDisable
Thank-you kindly, will try that immediately!
