This morning I tried to check the WiFi signal strength of one of my wireless speakers. I am used to go into the 4Stream App > tap the gear-icon of the speaker > Device Info > and then see the percentage that indicates the WiFi signal strength for that speaker.
But it seems to have disappeared from the 4Stream App.
My questions
- Is that correct?
- Or is it hidden somewhere else?
- How can I now check the WiFi signal strength?
Example of the old App showing WiFi signal strength (57% in this case):
Example of the current App, not showing the WiFi signal strength anymore:
